24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Curtain Wall sliding door family not centering
0 Posts No Rating |
Hi,
I have created this family for a curtain wall sliding door which is working well,
But. the center mullion as drawn in the block will not stay centered once loaded into the project. One leaf of the door will be for example 940 and the other 820.
Would anyone know how I can fix this?
Thank you,
Mal.
Have you modified the template family in any way, deleted parameters, changed constraints? I’m not exactly sure what is wrong with it, but you can unpin center ref plane, or start over.
0 Posts No Rating |
Hi,
I've used the family template which comes with revit called "Metric door - curtain wall" and continued from there. The template comes with a standard EQ from the center which i've maintained in the family, and which continues to work when I flex the model. It just doesn't stay EQ when in the project file.
I might try remaking it...
Curtain wall sliding door |
Fri, Jul 25, 2008 at 10:31:57 AM
Curtain Wall Door |
Mon, Aug 4, 2008 at 3:23:36 PM
Curtain Wall Panel to Curtain Wall Door |
Mon, Jun 23, 2014 at 9:32:11 AM
Cant load Curtain Wall Door |
Wed, Oct 26, 2011 at 3:41:44 PM
curtain wall door family always vertical? |
Thu, Aug 11, 2016 at 7:16:06 AM
