Forums >> General Discussion >> Revit Project Management >> Hide lines in tag with shared yes/no parameter from host
Sat, Oct 3, 2015 at 9:51:33 AM | Hide lines in tag with shared yes/no parameter from host
Sk1987
Hi all. I don't know if this question have been afsked before, but I can't seem to find it... I have a generic family with quite some yes/no parameter. I'd like these to hide/show some lines that have have made in a tag for generic families, but of my knowledge I can only refer to shared parameter as labels and not use these to hide/show lines and other stuff. Isn't it possible to do some kind of work around? I don't what to manually press the same yes/no parameter it the tag as in the actually family. I hope someone can help me. From Simon
Sat, Oct 24, 2015 at 10:39:06 AM | Hide lines in tag with shared yes/no parameter from host
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
In the family editor with the lines already drawn, create the parameters and make sure they are basd on on/off, select the line that needs to be controlled and in the Properties Box go to the visible parameter and click on the grey box in its far right. Choose the correct parameter and repeat for all other lines.
Load into project and test.
Using a Yes/No Parameter to control the visibility of another Label in a Tag
Wed, Feb 6, 2013 at 2:03:21 PM
Can't add shared parameter to material tag?
Mon, Jan 21, 2008 at 5:58:33 PM
Shared Parameter Over Constrained Planes
Thu, May 18, 2017 at 2:13:21 PM
Family type name as shared parameter?
Mon, Oct 10, 2011 at 8:28:04 AM
shared parameters and tags
Tue, Jun 12, 2012 at 2:15:25 PM
Page generation time: 0.5873
