Forums >> Revit Building >> Technical Support >> Certain views display blank SOMETIMES
Fri, Oct 2, 2015 at 2:16:59 PM | Certain views display blank SOMETIMES
spohler
We are using Revit 2015. When we try to open either Level 2 Ceiling Plan or Level 2 Working Plan (but not our Level 2 overall plan) they sometimes open with nothing displayed. If you close the view, open the corresponding Level 1 plan then open the Level 2, it will display.
Additionally (and this is the bigger issue), when exporting to dwg the views show up blank sometimes and with only grid lines sometimes.
Auditing and purging did not help. Deleting the view and recreating it did not help. Opening on another computer did not help. It is a workshared model.
Fri, Oct 2, 2015 at 4:14:00 PM | Certain views display blank SOMETIMES
I doubt that this is a revit issue.
Without knowing anything else, I suggest you turn off hardware acceleration under the revit R dropdown.
3d views disappearing
Mon, Apr 7, 2008 at 12:53:36 PM
Camera views export blank images
Mon, Dec 9, 2013 at 2:13:16 PM
Saving drafing view ends up blank
Tue, Mar 18, 2014 at 10:30:40 AM
display of families in different views
Mon, Oct 19, 2009 at 9:15:23 AM
11
text in family not display in schedule, fields blank in properties diaglog
Tue, May 17, 2011 at 6:29:13 PM
Page generation time: 0.5880
