Forums >> Revit Building >> Technical Support >> How many local files to keep??
Thu, Oct 1, 2015 at 5:26:25 PM | How many local files to keep??
dasher77
5 Stars: 2 Votes
Hi, this may seem like a silly question, but every month or so I archive our local files. I started doing this after talking to a guy with 6 years revit experience who said thats what he did. My problem is that it is takling up a lot of storage space. Yes I know I could copy it somewhere, but that is still valuable space being used. so my question is this:
Is it neccessary to archive the local files, and if so, how far back should I keep?
Thanks
Fri, Oct 2, 2015 at 7:31:44 AM | How many local files to keep??
Why would you archive local files?
Tue, Oct 6, 2015 at 3:40:28 PM | How many local files to keep??
dasher77
5 Stars: 2 Votes
Because our company archives everything, and it is what they were doing before I started. The out going Revit technician said that its a good practice to get into. I wasnt sure, but now space is getting precious. I assume from your statement that there is no real need to continue this practice? If so, now I need to try and convince management.....
Tue, Oct 6, 2015 at 4:05:44 PM | How many local files to keep??
If you create a new local every day as some people recommend, this would be crazy!
While working on a project, I will make a new local when I think I may want to freeze a copy of the project for possible reference.  When I finsh a project, I typically delete all of these files.  Our central file has archived files at each submission with their backup for any rollback possibility) and our server is backed up regularly.  I see no reason to do anything more.
Good record keeping means you also delete bad data.   If you talk to a lawyer, he will want yo to destry anything that may be in conflict with record documents.
Local Files and Reformatting my Hard Drive
Thu, Jun 7, 2012 at 8:24:39 AM
Local files keep becoming incompatible with central file!
Thu, Oct 28, 2010 at 9:39:23 AM
Back-up files and local files
Tue, Apr 17, 2007 at 8:19:10 AM
Deleting local files and copying files from central
Fri, May 23, 2008 at 11:28:55 AM
Revit local files = Workstation or server location
Mon, Mar 11, 2013 at 7:31:30 AM
Page generation time: 1.1851
