Forums >> Revit Building >> Technical Support >> Schedule multiple values as "Varies"?
Thu, Oct 1, 2015 at 10:00:11 AM | Schedule multiple values as "Varies"?
LJT1
Is there anyway to have a window schedule return "Varies"? For example if a window type has two different sill heights it will return a blank box, which looks like a mistake on a schedule, so traditionally one would enter the word "varies". Can it be done? Thanks
Thu, Oct 1, 2015 at 11:13:11 AM | Schedule multiple values as "Varies"?
No easy way to do this.  Easist is to use text in paper space but hard to manage.  You could add it in the remarks field.
Thu, Oct 1, 2015 at 12:05:44 PM | LJT1
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting LJT1 from 2015-10-01 10:00:11
For this very reason, I use tag by instance (mark vs. type mark). The same window type can be used in a lot of places and have different sill height, glazing, light&vent and exit requirements, new vs exist. opening, etc., etc. That’s where the tag by instance comes to the rescue.
Thu, Oct 1, 2015 at 12:28:04 PM | Schedule multiple values as "Varies"?
Obviously pijpiwo, yours is the best solution.   We never include sill height in the schedule because it is really irrelavant there.  It is more important at the window location.  We don't tag it, we dimension it in appropriate views.
Tue, Oct 6, 2015 at 2:51:04 PM | Schedule multiple values as "Varies"?
LJT1
@pijpiwo @wwhub thanks for the responses
"Room From" and "Room To" NOT updating in Door Schedule???
Wed, Jan 20, 2016 at 1:17:43 PM
"elevation at bottom" varies for wall?
Wed, Jan 22, 2014 at 4:56:33 PM
Stone patterns - "the pattern with the values you have supplied is too large"
Mon, Dec 7, 2009 at 1:27:33 AM
Auto "Quick" Schedule
Wed, May 28, 2008 at 1:08:02 PM
{3D} view set to "Shading with Edges" looks like "Wireframe" with color...
Wed, Aug 12, 2009 at 7:05:45 AM
11
Page generation time: 2.1456
