Forums >> Revit Building >> Technical Support >> Ceilings Not Showing In Elevation/Section
Thu, Oct 1, 2015 at 7:00:21 AM | Ceilings Not Showing In Elevation/Section
dkgrar
I have drawn several ceilings in my 12 story building in Revit 2014. When Icreate an elevation or section, no ceilings show up. It is not a visibilityproblem as the box is checked next to "Ceilings". It is not a filter asthere are no filters for my elevations/sections. The ceilings are also nothidden in the view as is evident when I toggle the hidden view on and off.Any ideas why they are not showing up?
Thu, Oct 1, 2015 at 7:07:35 AM | Ceilings Not Showing In Elevation/Section
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are they on the right phase? Are you using worksets?
Thu, Oct 1, 2015 at 7:13:04 AM | Ceilings Not Showing In Elevation/Section
dkgrar
I am not working in worksets and it is drawn in same phase as is shown in the elevation
Thu, Oct 1, 2015 at 7:31:33 AM | Ceilings Not Showing In Elevation/Section
Run some tests...
  • Set the view to coordination.   You don't say what the setting is.
  • Turn on all model categories in the view.  Anything there?
  • Turn all categories off except ceilings.  Anything there?
  • Cut a new section - sometimes views do become corrupt
Ceilings not showing
Fri, Aug 12, 2011 at 9:10:52 PM
Slanted wall in section & sloped ceilings
Wed, Feb 18, 2009 at 2:10:44 PM
Ceiling diffusers not showing up in ceilings when combined with architecturals
Wed, Sep 2, 2009 at 5:20:10 PM
Elevation Tags not showing when I cut a Section View
Mon, Oct 20, 2014 at 2:43:05 PM
Elevation shows as section
Thu, Sep 13, 2007 at 3:51:59 PM
Page generation time: 1.3094
