Forums >> Revit Building >> Technical Support >> Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
Wed, Sep 30, 2015 at 10:06:36 AM | Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
jsburt
I have multiple families that I am trying to make adjustable in terms of an angle.  For example an "L" shaped counter top that has a variable angle.  The issue I am having is that every degree works until a perpendicular angle is formed, at that point the object loses its connection to the reference line.  Is there any way around this.  I am assuming that it is something built in to revit that causes lines to snap perpedicular to other lines and at that point lose their ablity to rotate?  The reference lines work perfectly fine when they are by themself.  Has anyone else ran into this issue?
Wed, Sep 30, 2015 at 10:08:26 AM | Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
If you look through the similar threads, you will see that this issue has been discussed several times over the years.
Wed, Sep 30, 2015 at 10:28:32 AM | Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
jsburt
Any specifics?  I have searched and cant really seem to find anything similar.
Wed, Sep 30, 2015 at 11:03:49 AM | Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hey jsburt,
I created some families that had issues with angles. The issue I had was to do with the parameter control / angle of rotation. When the parameter was entered in the project the item would either going funny (weird angles occuring that were not as entered) or cause it to crash and throw up errors. The solution i used was to use one object within the family that could be rotated and another that could not. I then used IF statements to switch between the two visibilities and to prevent the user from entering in an angle that would cause the item to malfunction.
Is this similar to what you were talking about? If so you could adopt a similar approach. If not, could you upload your family and/or add some screen shots?
King Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Wed, Sep 30, 2015 at 12:28:52 PM | Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
Read this one: http://www.revitcity.com/forums.php?action=viewthread&thread_id=32545
material image at different angle
Thu, Oct 23, 2014 at 1:19:46 PM
Adjustable angle door family
Thu, May 14, 2009 at 2:30:09 PM
Adjustable Angle Countertop Family
Tue, Dec 9, 2008 at 3:03:26 PM
Getting angle parameter for a plywood fill region detail component to work SMART
Wed, Jan 15, 2014 at 7:27:39 AM
Cannot make 90 degree angle parametric family
Wed, Apr 11, 2012 at 7:40:02 PM
Page generation time: 0.5688
