Forums >> Revit Building >> Technical Support >> linking models via origin to origin problem
Wed, Sep 30, 2015 at 7:00:26 AM | linking models via origin to origin problem
KYLIEBRAITHWAITE
Hi,
Something strange is happening.
When I link a revit model to another revit model via 'origin to origin', it doesn't appear to be in the right place, just slightly off by approximately 4m. When I link a model I go to a plan view and make sure the orientation is 'true north'.
When I link the revit models via 'shared coordinates' it comes in perfectly.
We have been linking our CAD files to the model 'origin to origin' and we want to keep it that way.
When I link the CAD files to either of the revit models via 'origin to orgin' it comes in perfectly.
The problem only occurs between linming the revit models 'origin to origin'
Does anyone know what is happening here?
(Revit 2015)
Wed, Sep 30, 2015 at 8:25:43 AM | linking models via origin to origin problem
Origins in Revit are not the same as CAD.  You can read up on Revit origins in one of the old AUGI Edges magazines - probably 4 years ago....   If the Revit files are a copy, the origin works but shared coordinates is always the preferred method.  AND - Linking CAD origin to Revit origin makes absolutly no sense at all.  CAD file origins can be set - as far as I know, there is no way to set Revit origins.  ...
What this video to learn more about Revit project and survey settings and how to use these.
http://www.youtube.com/watch?v=BigvY4LT-RI
Wed, Sep 30, 2015 at 10:07:07 AM | linking models via origin to origin problem
Re-reading that 2009 article .... there is a way to find Revit's origin.   Read the article here:
http://www.digitaleditiononline.com/article/GETTING+ORIENTED+WITH+REVIT/168099/0/article.html
Wed, Sep 30, 2015 at 10:20:09 AM | linking models via origin to origin problem
KYLIEBRAITHWAITE
Great, thank you WWHUB.
I'll watch and read through the links now.
Origin to Origin
Tue, Jul 5, 2011 at 8:18:16 AM
Setting default linking position to "auto - origin to origin"
Wed, Feb 23, 2011 at 1:46:54 PM
Point Clouds Origin to Origin
Tue, Nov 8, 2011 at 11:23:30 AM
Mis-aligned Origin to Origin in linked Revit Architect into Revit Structures
Fri, Nov 18, 2011 at 7:26:33 AM
Acad Import - Origin to Origin
Wed, Aug 1, 2007 at 5:57:25 PM
Page generation time: 4.8995
