Forums >> Revit Systems >> Technical Support >> Duct pressure loss calculation
Tue, Sep 29, 2015 at 3:32:05 AM | Duct pressure loss calculation
drisan08
Hello!I'm using Revit MEP 2016. i have a project where i have to calculate the duct pressure loss of a system, but the calculation wasn't true because Revit assigned wrong ASHRAE table to some duct fitting. I tried to change the selected ASHRAE table and i could but i had to change it in every duct fitting. I couldn't mark out all the similar fittings and change the selected table because when i marked out the fittings, i didn't see the ASHRAE table list anymore. In a big project it's too consumptive of time to change the tables in every duct fitting one by one.1) Can i somehow affect the method what Revit use to select the appropriate teble?2) If i can't affect the method, do you have any idea to change the AHRAE table in more duct fittings at the same time?Thank you for your help and sorry for bad my english (it's my second language) and i hope i was clear.
duct static pressure loss
Mon, Aug 15, 2011 at 2:18:11 PM
ASHRAE TBL files and pressure loss calculation in Revit MEP 2012
Sun, Sep 4, 2011 at 4:32:06 PM
Heat loss calculation formula
Wed, Apr 29, 2009 at 10:09:09 AM
Duct Loss Coefficient not matching
Sat, Jun 1, 2013 at 10:41:33 AM
Flat Oval High Pressure Duct???
Sat, Oct 17, 2009 at 7:48:59 AM
Page generation time: 2.1355
