Forums >> Revit Systems >> Technical Support >> Creating Y/N Parameter
Sat, Sep 26, 2015 at 9:28:52 PM | Creating Y/N Parameter
duntonkm
I am trying to create a basic Y/N parameter to make a nested family visible or not visible based on which family type is selected. I have tried many different equations and the parameter is associated with the family I want to control, but nothing I have done is working. I am using Revit 2014. Any help will be greatly appreciated.
Sun, Sep 27, 2015 at 10:30:51 AM | Creating Y/N Parameter
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I’m assuming you have some families already loaded to the parent family. Highlight the family you want to control visibility, in the properties window you have ‘visible’ parameter already setup, now you need to associate it with the object. Click little rectangle to the right and set up your parameter (it is already yes/no). In the family types window, create new family type(s) and check or uncheck your newly created visibility parameter.
If you still having problems, can you upload your family? It would be easier to troubleshoot that way.
Wed, Dec 23, 2015 at 8:08:37 AM | Creating Y/N Parameter
Pikachu123
It's very important to have the yes/no parameter you associate the visibility with is a INSTANCE paramter, or else it is going to be controlled within the family file, or type based, instead of within the project. It allows more freedom, and you do not have to get into different types. It comes down to preference i guess. Hope it helps.
Creating Uneditable Parameter?
Wed, Mar 12, 2014 at 12:50:31 PM
CREATING NEW LABEL PARAMETER FOR TITLE BLOCK
Fri, Jun 9, 2006 at 12:16:03 PM
HELP.....Creating a 2d bed family
Mon, Feb 1, 2010 at 4:04:52 PM
How do you share a parameter between several different sheets?
Thu, Nov 10, 2016 at 3:15:54 PM
Creating nested Family Parameters
Fri, Jun 26, 2015 at 3:52:28 AM
Page generation time: 7.5700
