Forums >> General Discussion >> Revit Project Management >> Layout sheet - project status notification.
Sat, Sep 26, 2015 at 4:35:58 PM | Layout sheet - project status notification.
dvgareth77
Hello So my practice has drawing sheets in various sizes as am sure we all do. In autoCAD each sheet had a box that noted the project status so... Planning... Building control... Tender... As built Depending on the status we would solid hatch the box relative to it... In Revit we are struggling to create this parameter. Does anyone do this similar or have an idea how this can be facilitated? Thanks...
Mon, Sep 28, 2015 at 7:21:46 AM | Layout sheet - project status notification.
We have a simple parameter asigned to sheets that tells the sheet status.  It shows up under properties.
Mon, Sep 28, 2015 at 8:30:39 AM | Layout sheet - project status notification.
dvgareth77
Hi Thats exactly what we need to.
Is your parameter a text box because we have looked at that?
Ours is as the image and we are looking for the boxes to be hatched depending on status...
Mon, Sep 28, 2015 at 8:43:30 AM | Layout sheet - project status notification.
Like this?
Project Parameters / Instance / Assigned to sheets / Grouped under Identity / Y/N Field
Mon, Sep 28, 2015 at 8:56:57 AM | Layout sheet - project status notification.
dvgareth77
:-) Yes exactly!
exporting to dwg
Mon, Jul 19, 2010 at 2:56:49 AM
RVT to DWG export page layout settinigs
Fri, May 11, 2012 at 3:31:01 PM
help with sheet layout
Sat, Dec 6, 2008 at 10:30:32 AM
Status bar Jumble
Mon, Apr 30, 2012 at 1:08:29 PM
Drawing Sheet Box around layout?
Sat, Dec 3, 2011 at 5:02:34 AM
Page generation time: 1.3781
