14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> moving half a building
26 Posts No Rating |
I have to take a narrow section out of the center of my 3 story condo building.
Once the section has been removed I want to bring the two halves back together.
How do I select the entire building, contents and all?
Or is there another way?
Need help fast.
do it from a 3d view and switch back to a plan view
best regards,
coreed,aia
its not easy in revit..cus many object might be links...depends on how the model was built...my suggestion are.....
1) Save a back-up copy!!!
2) Delete the portion
3) Group the portion/part you want to more,
4) Pray + close bizzilin warning window that pops up...
hope that helps
Thanks for the input.
I did save a copy before I started,
then took a slice out of the building
then went 3d, selected everything on right side of building
went to 2d to fine tune and "move"
then went back to 3d, selected everything on left side of building
and so dragged the two halves back together.
My wife will wonder why I have more grey hair than I did when she left this morning.
Now comes the long process of tweekking and making sure everything is okay...
lots of elements in this building including decks, complex roof, stairs, groups, elevator, yada yada
chock full of stuff...was this close to getting final on all floor plans.
Site Plan & Moving Building Model |
Fri, Mar 9, 2007 at 10:22:55 AM
Moving Building up with out moving the site |
Sun, Jul 31, 2016 at 5:20:10 PM
Rotating property line and site without moving building... |
Sat, Jun 15, 2013 at 10:31:20 AM
Changing level height values while keeping building in place? [ 1 2 ] |
Mon, Apr 13, 2015 at 1:47:48 AM
18
Moving a Building |
Wed, Apr 30, 2008 at 5:49:59 AM
