Forums >> Revit Building >> Technical Support >> JUMBLED DWG TEST
Sat, Sep 19, 2015 at 12:22:04 PM | JUMBLED DWG TEST
Wader
I'm trying to link a dwg full of written text into revit but a portion of the text misaligns and doesn't wrap properly.
I have a work around by printing it as a pdf and exporting as a jpg...then inserting that image.  It definately saves
time over retyping all of the text in revit but could be a real issue if some if the tects needs to change in the future.
A linked DWG would be the best solution f there's a way to get the text to format propoerly.  Any suggestions?
Sun, Sep 20, 2015 at 9:21:01 AM | JUMBLED DWG TEST
I have seen this problem may times.  It is caused by how the text was done in CAD.  JPEG's can be huge and may cause you problems so we try not to use that solution.
If the text may change, I will usually open the CAD side by side with the Revit and use copy paste (ctrl-c/ctrl-v) to Revitize the text.  But you have to be careful of the mix of fonts they may be using and special characters in the CAD.
dwg imort problem: arrowheads missing, text jumbled
Tue, Nov 17, 2009 at 9:16:55 AM
1 hour practical Revit test at interview
Thu, Aug 7, 2014 at 11:00:46 PM
some test results you might want to check out...
Thu, Oct 12, 2006 at 5:17:27 AM
exporting to dwg
Wed, Aug 18, 2010 at 5:10:21 AM
Ribbon Tabs jumbled up
Mon, Oct 19, 2009 at 12:07:04 PM
Page generation time: 0.1147
