24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Importing old Font
The firm that I work with has been using the same font for 20 years. Arch.shx is not a Word True Type font. I am setting up our Revit template and titleblock and need to find a way to import this font into Revit. Any ideas, or am I stuck with Word fonts?
Chris
This is my first post on revitcity.com. I look forward to working with all of you and this great software.
well I am in the same boat....any takers on this subject
I really want this to work...some good things some bad |
you will have to find a True Type Font that's similar to the Arch.shx . As far as i know you will not be able to access any .shx fonts in Revit. only Windows installed fonts are accessable HTH
I did eventually find a True Type Font that matched close enough. We are now using ARchitxt.ttf with all of our software, Revit and AutoCAD alike. This font is very similar to the Arch.shx font that we used before. If you do a search on this site (in the Forums) you should be able to find it for download. Good Luck
----------------------------------- ArchWestCY |
cool....but I still need a solution....see I am going from an Intergraph product to Microstation to Revit and back....a close match will not do....
The only advise I have is to use the ARchitxt.ttf font for all of them.
Importing a font into Revit |
Thu, Jan 30, 2020 at 6:14:15 AM
Importing Text from AutoCad |
Thu, Sep 2, 2010 at 12:50:23 PM
Autocad model importing. |
Wed, Nov 29, 2006 at 8:44:38 AM
CIS/2 exporting and importing |
Tue, Feb 26, 2008 at 7:42:52 PM
Importing SHX font from ACAD into Revit |
Wed, Oct 18, 2006 at 9:24:53 AM
