Forums >> Revit Building >> Technical Support >> REVIT 2014 ELECTIRCAL SCHEDULE
Thu, Sep 17, 2015 at 2:49:16 PM | REVIT 2014 ELECTIRCAL SCHEDULE
WinterRiver1971
Hello
I can't add a total count in the formatting field for electrical families in the schedule. Any ideas? The calculate totals is greyed out.
Thu, Sep 24, 2015 at 1:02:06 PM | REVIT 2014 ELECTIRCAL SCHEDULE
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
There are a few 'Total' type fileds in REVIT schedule so you're going to have to clarify exactly what fields you want to total and from which 'Tab' of the scheduling dialog box you are refering to.
There is No 'total count' fiels on the Formatiing tab. There is a 'Calculate Totals' field on the Formatting' tab. This adds 'numbers' and  Integers' from the selected field such as total length or total weight or total volume.
If you want to 'Count' how many elements are listed in the schedule you have to make sure the 'count' field has been added to the schedule as a field then use the Totals options at the bottom of the Sorting/Counting tab.
You may also have to specify something in the 'Sort by' field to make the totals work.
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Freezing Headers in Schedule - Revit 2014
Mon, Jul 1, 2013 at 11:11:36 PM
Revit 2014 Structural Foundation Schedule
Thu, Sep 17, 2015 at 3:02:41 PM
Analytical Lines creates blank space in schedule in revit str 2014
Thu, Sep 11, 2014 at 8:10:30 AM
Floor finish schedule - Revit 2014
Wed, Mar 26, 2014 at 10:32:59 AM
Page generation time: 1.6815
