Forums >> Revit Building >> Technical Support >> Attach Building Section Heads to Section Box
Wed, Sep 16, 2015 at 9:41:35 AM | Attach Building Section Heads to Section Box
cboersen
Using Revit 2014 on Windows 8.1
After I place a building section the section box is not attached to the section heads.  I have noticed that occosionally they do seem to be linked and if you move one the other will move as well but I cannot figure out how to control that function.
Is there a way to manually attach and detach the section box to and from the section head for a building section?
Mon, Sep 21, 2015 at 4:53:57 PM | Attach Building Section Heads to Section Box
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I've seen that with elevations but not sections ? And no as far as I know you cannot lock the two together. And yes it can be a pain to work with.
Section Heads
Sat, Jun 10, 2006 at 9:49:47 PM
Section Heads
Tue, Nov 24, 2009 at 4:51:48 PM
Section heads - (Revit 2010)
Mon, Nov 16, 2009 at 12:48:38 PM
Section box in Section??
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section heads keep moving when view is cropped!
Fri, May 15, 2009 at 10:06:36 AM
Page generation time: 0.4772
