Forums >> Revit Building >> Technical Support >> Need to break plan into two large plans.
Wed, Sep 16, 2015 at 9:08:17 AM | Need to break plan into two large plans.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I have googled and searched but, so far, have not stumbled onto an explanation of how to do that in Revit 2015.  Can anyone point me in the right direction?
Wed, Sep 16, 2015 at 9:42:40 AM | Need to break plan into two large plans.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We need more information.  What are you breaking up?  You can use worksets and link files.  If the plan is already started you will have to copy out what you want to a new file, this may end up being a pain depending on how much is done already.
Wed, Sep 16, 2015 at 9:53:37 AM | Need to break plan into two large plans.
  1. Create an overall plan at the correct scale.   This will have all annotations and will be 1/2 your building eventually.
  2. Place your MATCH-LINE
  3. Set up the crop region for this first plan.
  4. Create a dependent view of this first plan and set the crop region for the second half. (Make sure the crops overlap.)
  5. Now place these views on seperate sheets.
  6. Add a view reference at the matchline to point to each sheet.
Wed, Sep 16, 2015 at 9:55:32 AM | Need to break plan into two large plans.
Here is a tutorial: http://www.revitzone.com/presentation-and-graphics/168-matchlines
Wed, Sep 16, 2015 at 10:04:17 AM | Need to break plan into two large plans.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Great!  Thanks for the link to the tutorial.
Wed, Sep 16, 2015 at 10:11:32 AM | Need to break plan into two large plans.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Is it possible to have the main view be a smaller scale and the dependent views that are matchlined be at a larger scale and have all changes created on the main view show up in the dependents?
Wed, Sep 16, 2015 at 10:57:50 AM | Need to break plan into two large plans.
Short answer NO.
The overall view has everything in it and there is only one dependent view - not two.   The overall (let's say left side) and dependent view (let's say right side) have to be the correct scale because they are sheeted.  You can move annotative elements in either view to adjust them at the match-line.  But initially, you want to work with the view not cropped so dimensions can cross the match-line.
You need to work with this a little to understand the concept .... AND it works very, very well!
Unit Plan / Key Plan
Mon, Mar 20, 2006 at 4:41:24 PM
Overall Plans and Partial Plans ... looking for Best Practice [ 1 2 ]
Sun, Jul 21, 2019 at 7:44:21 AM
15
How to Break up a Large Project.
Fri, Feb 15, 2013 at 10:58:44 AM
site plans and buildings plans
Tue, Apr 17, 2012 at 8:40:07 AM
Stair Break Line Customization
Mon, Dec 12, 2011 at 4:20:09 AM
Page generation time: 0.4668
