Forums >> Revit Building >> Technical Support >> Stack/Offset Elevatios and Building Sections that are too Long.
Mon, Sep 14, 2015 at 12:26:31 PM | Stack/Offset Elevatios and Building Sections that are too Long.
cboersen
Revit 2015 on 8.1
I would like to know if there is a way to break and offset a building section and or elevation views.  I know how to break a view and shorten an elevation or building section. but I have a case where I need to see the full length and it will not fit on a sheet.  Do I have to use two building sections or can a brioken view be offset like you can schedules?  Thanks.
Mon, Sep 14, 2015 at 2:50:04 PM | Stack/Offset Elevatios and Building Sections that are too Long.
You will have to use two elevation views.
More stack wall problems!
Sun, Apr 8, 2007 at 3:40:16 PM
Quoin stack
Sun, May 10, 2009 at 4:44:28 PM
building sections visible but detail view sections NOT visible on all drawings??
Tue, May 27, 2008 at 12:50:20 PM
imported grid offset from crop region
Fri, Sep 19, 2008 at 4:47:10 AM
Annotating Building Sections/Wall Sections/Details [ 1 2 ]
Thu, Mar 17, 2011 at 2:54:40 PM
15
Page generation time: 1.9335
