Forums >> General Discussion >> Revit Project Management >> Room tag
Sun, Sep 13, 2015 at 11:49:30 AM | Room tag
deusdara
Hi,
working with Revit, I can assign each wall, ceiling and floor with finishing materials. In this way, each room has a finishing material defined to floor, wall and ceiling but the connection between finishing materials already applied and the tag room is not automatic; therefore, it´s possible assign a tag value without conetion with the real material applied.
Is there any way to assign values in a tag room to floor, wall and ceiling automatically?
Thanks
Mon, Sep 14, 2015 at 2:59:23 AM | Room tag
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
It's a little tricky to interpret your question but if I understand it correctly the answer is 'no' you cannot apply 'room finish materials' to the walls floors and ceilings for tagging. Wall tags display only wall materials not room finish materials. Same for floors and ceilings.
Mon, Sep 14, 2015 at 7:10:57 PM | Room tag
deusdara
thanks for the feedback; the question is not to apply finishing materials in a room from the tag but the opposite of this: from a room with floor, walls and ceiling finishig materials defined, display this information in a tag room.
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
Room Tag Leaders
Thu, Oct 21, 2021 at 9:45:56 AM
ROOM TAG TAGS ONLY HALF OF THE ROOM
Wed, May 6, 2015 at 8:58:21 AM
Page generation time: 1.8230
