Forums >> Revit Building >> Technical Support >> Corner Windows
Thu, Sep 10, 2015 at 6:45:10 PM | Corner Windows
lpluger21
Is there a way to get both width dimensions to scedule for a corner window? Even if I have to manually enter the second dimensions. I am looking for it to look something like this. Thank you!
Thu, Sep 10, 2015 at 9:08:03 PM | Corner Windows
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
It depends on how the window family is built. See this. It will give what you need.
Fri, Sep 11, 2015 at 9:59:07 AM | Corner Windows
lpluger21
Thanks for the post but I'm not sure how that helps. I looked at the family and the way it is set up it just constrains both widths to be the same. It doesn't give a field for the second width to be scheduled either. Even if both widths we going to be the same, I would still need to have 2 separate fields for left and right in the schedule like in my origional post. I have already built the family I need, I just need to be able to schedule it.
Fri, Sep 11, 2015 at 10:35:35 AM | Corner Windows
If you nest one window family (shared) into another window family, they will both schedule.
Fri, Sep 11, 2015 at 10:41:08 AM | Corner Windows
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
It looks like you haven’t looked at the family carefully enough – see picture.
If you have your window family built already, add second shared parameter for width 2.
Fri, Sep 11, 2015 at 11:03:10 AM | Corner Windows
lpluger21
Awesome!  Thanks pijpiwo, that got it working. I'm still a newbie when it comes to shared parameters. I always forget about them. i'm not usre about how to specify right and left but width 1 and width 2 will do for now!
Corner windows with variable angle
Tue, Dec 27, 2016 at 4:47:10 PM
corner windows
Tue, Jun 3, 2008 at 10:56:06 AM
Corner windows
Thu, Apr 10, 2008 at 9:14:45 AM
Corner Windows
Sun, Feb 25, 2018 at 6:27:00 AM
Corner windows
Tue, Aug 2, 2005 at 1:51:34 PM
Page generation time: 1.5488
