Forums >> Revit Systems >> Technical Support >> COLUMNS CAST WRONG SHADOWS
Mon, Sep 7, 2015 at 10:47:33 AM | COLUMNS CAST WRONG SHADOWS
LOSpistos
Hi,
Please find attached the image showing the columns with the wrong shadow represenation. The columns run through the whole building and from the attached picture is looks like they are floating in the space, which is not true. I doublechecked the 3D. Ground Plane for shadows is set up for the actual level.
Can somebody addvice on what can be the issue?
Many thaanks
Mon, Sep 7, 2015 at 1:05:36 PM | COLUMNS CAST WRONG SHADOWS
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I’m not exactly sure why this is happening, but if you set the view range cut plane in the family to be above the cut plane in the project, it works fine then.
convert generic wall and roof to cast colored shadows
Sat, Oct 20, 2012 at 6:05:40 AM
Linked Models don't cast shadows???
Mon, Sep 27, 2010 at 8:48:07 PM
Shadows on plan view cast from cut plane
Wed, Sep 24, 2008 at 9:24:32 AM
Shadows on floor plans
Sat, May 18, 2013 at 7:41:40 PM
Some trees not casting shadows
Thu, Oct 16, 2014 at 10:55:22 AM
Page generation time: 0.1908
