Forums >> Revit Building >> Technical Support >> BUG REVIT 2016? ELEMENTS DISAPPEAR, DON'T SHOW UP PROPERLY
Mon, Sep 7, 2015 at 1:06:42 AM | BUG REVIT 2016? ELEMENTS DISAPPEAR, DON'T SHOW UP PROPERLY
jherrerovlc
Hi All,
I hope someone could help. We are working in a project fully developped in RVT 2016 and the deadline is quiet tight. I detected yesterday something that looked like a bug, and it affect to the visualization, because the elements dissapear when I zoom in & out.
We work for several years with revit and we can't figure out what's happening. I know that sometimes elements in revit can "disappear" because several reasons, but we have already checked every visibility filter, override, template etc and nothing. That's why we are almost sure that this could be a software related software, what I hope it's not.
Sign 1_
When I zoom in a normal plan view some elements disapear and others just pop up. In the attached image "01_Possible Revit Bug" you can see the same view without changing anything. I've tried printing, to see if we could continue working despite the error but even the generated Pdf file is corrupt, I ramdom elements are not showed.
Sign 2_
In the attached image "02_Possible Revit Bug" you can see that you are able to select the geometry that it's not show. So, the element is there, but it is not visible. Argh!!
I ask for someone who has had the same issue. I couldn't detect any major change made in the model that could cause this in the last days.
I tried in other computer with RVT 2016 and it doesn't solve the problem.
I copied some elements to a new project and the problem seems be solved, although, if I copy and save all the elements, phasing setting would disappear. Definitely this is not a solution because we are working in a renovation project and phase setting are necessary to be kept.
Tue, Sep 8, 2015 at 8:00:54 AM | BUG REVIT 2016? ELEMENTS DISAPPEAR, DON'T SHOW UP PROPERLY
If this is CAD, then that is your problem.
Tue, Sep 8, 2015 at 11:49:39 AM | BUG REVIT 2016? ELEMENTS DISAPPEAR, DON'T SHOW UP PROPERLY
revitape
revitape Avatar
4.5 Stars: 9 Votes
Your issue might be the phasing visibility settings
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Levels don't always show up
Fri, Jun 24, 2016 at 7:14:54 AM
Room Colors don't show in R2010
Thu, Aug 13, 2009 at 11:38:19 AM
BEWARE - Parameters don't update.
Thu, Sep 1, 2005 at 11:36:58 PM
revit 2016 - GRID LINE(S) SHOW IN ONE PLAN AND NOT THE OTHER
Tue, Feb 14, 2017 at 5:49:46 PM
hiding items in views??
Mon, May 15, 2006 at 8:24:35 PM
Page generation time: 2.7738
