Forums >> Revit Building >> Technical Support >> "Software Problem" prevents a project from opening.
Thu, Sep 3, 2015 at 5:51:34 PM | "Software Problem" prevents a project from opening.
whoopsyvroom
When I try to open a selected project a box with "Software problem" appears. Other projects work ok. How can I rectify this issue. I am using 2013 version.
Thu, Sep 3, 2015 at 6:07:42 PM | "Software Problem" prevents a project from opening.
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Had you previously been able to open this project?
Thu, Sep 3, 2015 at 7:08:14 PM | "Software Problem" prevents a project from opening.
whoopsyvroom
Yes It was operating last night. It has only happened when I tried to open the project this morning.
Fri, Sep 4, 2015 at 7:14:21 AM | "Software Problem" prevents a project from opening.
ARe you opening Revit then the project or are you just double clicking on the file.
Fri, Sep 4, 2015 at 8:28:40 PM | "Software Problem" prevents a project from opening.
whoopsyvroom
Tried both approaches. Tried rebooting which was done on the offchance somethi9ng may have not loaded correctly. Tried with another project allready open. Everything else operates perfectly.
Tue, Sep 8, 2015 at 7:55:38 AM | "Software Problem" prevents a project from opening.
First - Opening a project by double clicking on the file is not recommended practice.
Your file is corrupted somehow.  If you have a good backup, then use that.   If you are on subscription, you can have autodesk look at the file.
Tue, Sep 8, 2015 at 5:14:12 PM | "Software Problem" prevents a project from opening.
whoopsyvroom
Thank you for the responses.
We spent time trying to resolve the problem but in the finish we redraw the project. We spent about 3 hrs trying to recover the corrupted file and in the finish spent 4 hrs redrawing it from scratch. It was a reminder of weighing the time spent recovering a file compared to how long it would take to start again from scratch. A lesson relearnt.
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
Problem opening "component" version 9.1 in revit version 9.1
Fri, Jun 15, 2007 at 8:25:21 AM
Revit "appcrash" error
Tue, May 25, 2010 at 2:48:11 PM
Wall Opening conflicting with Wall Reveal
Tue, Feb 2, 2010 at 4:14:24 PM
Demolishing an existing door, putting an opening in its place....
Tue, Dec 6, 2005 at 5:04:38 PM
Page generation time: 2.4260
