Forums >> Revit Building >> Technical Support >> Roof join/void form problem
Thu, Sep 3, 2015 at 8:26:16 AM | Roof join/void form problem
gaudiman
Hello,
So i have a problem joining two roofs/voiding the part of the roof that should not exist. I must not they are on two different levels as its a split lvl house so i am unable to create it as one roof. Every time i have tried to model in place a void (ive tried extrustion, and blend) the roofs unjoin. I need a way to model the roof, i have attached photos to help depict what i'm trying to do.
It is an already existing building so there is nothing i can change in design to modify it, it needs to be exact.
Any help or ideas on different ways to model it or fix the problem would be greatly appreciated, thank you in advance.
Thu, Sep 3, 2015 at 8:54:16 AM | Roof join/void form problem
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
It is possible with a single roof. Take a look at the enclosed file.
If you have to, do not use void to cut the roof. I'd modify the footprint, or use vertical opening tool, easier to handle.
Edit: see this http://www.revitcity.com/forums.php?action=viewthread&thread_id=34839
Edited on: Thu, Sep 3, 2015 at 9:01:39 AM
Thu, Sep 3, 2015 at 9:25:44 AM | Roof join/void form problem
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
As an alternative, with 2 roofs...
Thu, Sep 3, 2015 at 9:32:53 AM | Roof join/void form problem
gaudiman
I'm stuggling to find out where to place that incut shape you have and at what depths on the footprint.
Thu, Sep 3, 2015 at 9:38:26 AM | Roof join/void form problem
gaudiman
Wasn't able to to do it by one roof for some reason, trying to create that divit in the footprint left a blank spot where it didnt come up to the building, ended up just editing the footprint of the roofs that were joined together using the join angle as a reference.
Edited on: Thu, Sep 3, 2015 at 10:04:40 AM
Edited on: Thu, Sep 3, 2015 at 10:22:15 AM
Thu, Sep 3, 2015 at 10:33:18 AM | Roof join/void form problem
pijpiwo failed to tell you that that little piece of roof under the other roof is a simple, single slope roof joined to the other roorf.
Thu, Sep 3, 2015 at 11:32:59 AM | WWHub
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting WWHub from 2015-09-03 10:33:18
Actually no. It's all one roof, no pieces.
Gaudiman, there is a file I have posted in version 13 - follow the link in post #2 above. Take a look.
Edited on: Thu, Sep 3, 2015 at 11:33:55 AM
Thu, Sep 3, 2015 at 12:31:07 PM | Roof join/void form problem
I had not seen that done - thank you.
Wed, Aug 14, 2024 at 4:51:22 PM | Roof join/void form problem
kellynorris40
I have an updated question here: https://www.revitcity.com/forums.php?action=viewthread&thread_id=43787
Void Form problem!!
Sun, Mar 3, 2013 at 11:36:34 AM
void form and cuttng void form
Fri, Jul 9, 2010 at 12:39:02 PM
Roof join (s)
Tue, Feb 14, 2012 at 8:11:44 PM
Roof Join Problem
Sat, Feb 4, 2006 at 3:07:35 PM
Void form issues once again. Few question
Thu, Mar 31, 2016 at 2:47:22 PM
Page generation time: 0.8282
