Forums >> Revit Building >> Technical Support >> Black FIll Under elevation
Wed, Sep 2, 2015 at 7:46:30 PM | Black FIll Under elevation
rdavies1973
rdavies1973 Avatar
Hi All
Revit 2016 is the version.
Image attached.
The situation: Got a job with a high elevation (approx. 196m as shown in the level markers). Each time I do this, I get a massive 'fill' from the top of the toposurface (196m in this instance) all the way back to 0.0m.
Really irritating. I'm guessing there is a relatively simple fix but haven't figured out the right google 'question/phrase to find the answer.
Rhys
Wed, Sep 2, 2015 at 10:12:18 PM | Black FIll Under elevation
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
See picture, or use crop region.
Wed, Sep 2, 2015 at 11:49:41 PM | Black FIll Under elevation
rdavies1973
rdavies1973 Avatar
Thanks for that ... however, it is not an poche issue.
Filled region is one '2D' way of working around it, but want the parametric solution if there is one.
Rhys
Thu, Sep 3, 2015 at 12:52:32 AM | Black FIll Under elevation
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
iIf it's the topo surface then it should be the Poche depth. . . otherwise what exactly are we seeing in your image ?
Thu, Sep 3, 2015 at 7:42:44 AM | Black FIll Under elevation
Not just poche depth but what pattern for the poche.  Black solid fill?
Thu, Sep 3, 2015 at 9:36:26 AM | Black FIll Under elevation
Roger1w
What about using a scope box around your project.
I have worked with companies that have a template the has a preset scope box that relates all their elevations and 3d views.
White text on Black background
Thu, Aug 9, 2007 at 3:05:05 PM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Material shows up black in elevation with model display set as realistic view.
Thu, Sep 1, 2016 at 9:50:56 AM
Solid Fill Pattern
Wed, Jan 9, 2008 at 1:55:24 AM
Fill Pattern
Mon, Jun 5, 2006 at 8:13:21 PM
Page generation time: 3.4252
