Forums >> Revit Building >> Technical Support >> Linked Cad - Global Lineweight
Mon, Aug 31, 2015 at 5:53:35 PM | Linked Cad - Global Lineweight
CRREVIT
Hey Guys,
I’m trying to make a global lineweight setting when linking CAD drawings into Revit. As of right now, If two Cad drawings are linked into the same Revit file, using the same layers, I have to change the lineweight for the same layer twice. Is there a way to globalize this to where I can change the lineweight once and it changes for all other instances that the specific layer is linked.
Tue, Sep 1, 2015 at 7:44:03 AM | Linked Cad - Global Lineweight
From your HELP.
Wed, Sep 2, 2015 at 3:35:49 PM | Linked Cad - Global Lineweight
CRREVIT
I was able to find information on importing CAD files, but I still cannot find anything about lineweights on linking CAD files. Do you know if the method is similar?
Wed, Sep 2, 2015 at 3:51:17 PM | Linked Cad - Global Lineweight
They are treated the same.
Wed, Sep 2, 2015 at 4:54:03 PM | Linked Cad - Global Lineweight
CRREVIT
Thank you! That worked!
I need Global Project changes to CAD Import lineweight, linetype, etc.
Mon, May 3, 2010 at 11:27:12 PM
Linked Cad File - Lineweights
Tue, Nov 18, 2014 at 10:20:58 PM
Coordinating Lineweight of Revit to Cad
Fri, Dec 7, 2007 at 11:17:24 AM
(2015) import (link) CAD to Revit screened lines (lineweights)
Wed, Sep 30, 2015 at 2:20:54 PM
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:14 AM
Page generation time: 0.3080
