12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Stair Line Control
4 Posts No Rating |
OK. This is probably really simple, but I'm missing something. I'm doing a restoration of a 1885 large victorian. Stairs are existing, so I put them on this phase. They look fine on existing plans with the lines dashed 1/16" gap above the cut line. On plans for new phase the stairs show up as grey lines, but the lines above the cut are solid grey also. A very confusing mess. What is the solution to this problem I am experiencing? I looked for a parameter that might fix it but to no avail.
Tom
2 Posts No Rating |
Open up the visibilty/ graphic overides and scroll down to stairs. Un check the "stairs beyond cut line" and "stringers beyond cut line" that should fix the problem.
4 Posts No Rating |
Thanks for the insite. That was very helpful. I am surprised I didn't see that before!
Changing walk line |
Tue, Aug 20, 2013 at 9:50:51 AM
Stair Cut Line : Double Line |
Mon, May 18, 2015 at 3:19:08 AM
Stair Break Line Customization |
Mon, Dec 12, 2011 at 4:20:09 AM
Stair break line problem |
Fri, Jul 17, 2020 at 4:21:45 PM
Line weight control |
Tue, Nov 21, 2017 at 2:14:39 AM
