16 Users Online (14 Members):
Forums >> Revit Systems >> Technical Support >> Family
0 Posts No Rating |
I have created a family with only one element for a bracket. Looks good in the different views including 3d view. But when
loading and placing that component into a floor plan, the element changes; the holes are in different locations, the overall
length is different, etc.; even the locked parameters have changed.
I am using Revit LT 2015
Any help would be appreciated
We can't really help because you have not given us anything to work with.
- The actual family would help but if not that then at least:
- Kind of family
- Hosted ?
- What are the 'holes and how were they created?
- You say locked parameters have changed... Then something wasn't made right but we sure can't guess.
0 Posts No Rating |
Sorry I'll try to be clearer
- It was a generic family
- It was not hosted
- The bracket had a 1/4" thick plate on the bottom in the horizontal plane. The holes were void extrusions
Your problem then is how you constrain and define your object in the family. Remember to always have your reference planes and lines established before you add your solids and voids. Don't lock everything. Flex your family by changing your variables before loading it into a project.
Create a family that includes another family |
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family? |
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project |
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message |
Wed, Aug 26, 2020 at 11:19:36 AM
Text(family #1) not showing after loading into family #3 |
Mon, Jan 19, 2015 at 2:43:21 PM
