Forums >> Revit Building >> Technical Support >> Parameter in Revit
Thu, Aug 20, 2015 at 4:24:09 AM | Parameter in Revit
elmitodeherta
Good morning, I 'm looking for a parameters list to insert into a bearing wall in concrete, such as compressive strengths, Flexural Strengths, Modulus of Elasticity, ductility, density, resistance to abrasion and corrosion etc...
Thu, Sep 3, 2015 at 1:08:07 AM | Parameter in Revit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Walls are System families so just add those parameters as Project Parameters for the Wall Catergory and use Shared Parameters if you want to use the data in a schedule or a tag.
Family with coordinate parameter? - Revit 2010
Wed, May 12, 2010 at 3:45:58 AM
11
Parameter Jerk 2012 Released
Mon, Sep 12, 2011 at 10:47:07 AM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
Parameter names with dashes - problem with formula
Tue, Aug 31, 2010 at 10:28:39 AM
Page generation time: 1.4581
