Forums >> Revit Building >> Technical Support >> Importing detail into title block
Wed, Aug 19, 2015 at 11:25:14 AM | Importing detail into title block
ABergman
Hello! I have made a Detail Item I want to use around the edges of my titleblock. Unfortunately revit has a problem loading Detail Items into the Titleblock. Is there a trick for getting this to work? Maybe a work around? Any help would be greatly appreciated. Thank you!
Wed, Aug 19, 2015 at 12:19:02 PM | Importing detail into title block
Export to CAD to make it be linework, clean it up and import or copy/paste linework.
Wed, Aug 19, 2015 at 12:45:02 PM | Importing detail into title block
ABergman
Thank you! It works great!
Importing Arch. Title block with all info.
Mon, Mar 30, 2009 at 4:55:02 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
Importing a title block from cad
Fri, Mar 28, 2008 at 11:55:35 AM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:23 AM
Page generation time: 0.3185
