Forums >> Revit Building >> Technical Support >> Bricks - Honeycomb bond in Revit
Tue, Aug 18, 2015 at 8:32:05 AM | Bricks - Honeycomb bond in Revit
aehryl
Hi, I've been struggling in a project where I have to make a honeycomb bond wall. I tried to create a curtain panel then just insert the generic model but the file run slow. I tried to create a wall and just add voids in it but it took a lot of time. I tried to create a simple generic family box for the brick then I nested it to the family where I array the bricks. It did the trick but it wont register as a wall in revit. Is there any other way to solve this?
Tue, Aug 18, 2015 at 9:00:15 AM | Bricks - Honeycomb bond in Revit
The answer is in the similar threads below.  Check out this one.  The void can be full depth.
running bricks
Wed, Oct 8, 2008 at 2:51:43 PM
Custom Running Bond Brick Pattern
Fri, Aug 26, 2016 at 2:38:25 PM
Open Bond
Thu, May 19, 2011 at 11:01:40 AM
4’ x 8’ running bond hatch.
Thu, May 8, 2008 at 7:02:50 AM
Double layered honeycomb facade
Thu, Apr 3, 2014 at 9:29:17 AM
Page generation time: 5.3547
