Forums >> Revit Building >> Tips & Tricks >> Move multiple detail objects at once without selecting the model beyond
Thu, Aug 13, 2015 at 5:17:01 PM | Move multiple detail objects at once without selecting the model beyond
AlderArchitecture
  • I have a contractor who decided today, after the drawings were complete to raise the plate height of the building up by one foot. All of my sections and elevations are in 2D detail lines and regions over the model. Many parts of the model are hidden.
  • I tried to pin everything in the 3d model then go to the 2D elevations select and move, but no luck. Because I end of grabbing the model behind everything. It says items are pinned and won't just move the ones that are not pinned. GRRRRR
Thu, Aug 13, 2015 at 5:29:34 PM | Move multiple detail objects at once without selecting the model beyond
Looks like you took a big learning hit but this will be helpful for the future.  If you model well, then by using edit cut profile, the linework tool and just a few detail elements, you can have real model sections.  Something to look at in the future.  This is the only way we do wall and building sections as well as some details.  Let the model do your work.
For now, I suggest you
  1. open up each view, turn off the model (although you say it is off) window the detail elements including linework and unpin.  Over use of pinning is a common user problem.  Pay attention to your selection filter to do this.
  2. Once you have gotten rid of all your pins, you can move your model elements up.
  3. Now go back into your views and window the elements that needed to move and move them up as a unit.
Good luck next time.
Thu, Aug 13, 2015 at 5:42:07 PM | Move multiple detail objects at once without selecting the model beyond
AlderArchitecture
The FILTER, AWESOME....works great.
Thank you!
I would love to model more to create sections and less work, however, it just takes so much time......I don't have this down to a science yet.  But I am getting better.
Thank you again.  May see me more as I tackle more modeling.
Revit moves objects just by selecting them?????
Wed, Jul 17, 2013 at 11:53:34 AM
Move objects on multiple levele
Thu, Oct 30, 2008 at 2:35:22 PM
Multiple revit building with one standard detail sheet
Mon, Jan 21, 2008 at 12:28:12 AM
How to move a single level datum without moving anything in model
Tue, Sep 29, 2015 at 1:53:58 PM
Selecting Objects on floor below
Thu, Nov 29, 2012 at 2:54:55 PM
Page generation time: 1.1485
