Forums >> Revit Structure >> Technical Support >> Cut Geometry in 3D
Sun, Aug 9, 2015 at 10:03:36 PM | Cut Geometry in 3D
tonywheal2
HI,
I am new to 3D modelling of rafters etc.  I have created a series of rafters along a reference plane so that's fine, but when I come to do a plumb cut on the rafter ends I cannot seem to do it to a reference plane unless I'm in 2D.  I can show the reference plane, and select a rafter to cut geometry with the plane, and the cut geometry plane icon comes up when I do that, but I can't clieck on the reference plane, hence the geometry cut does not occur.
Any thoughts, please?
Sun, Aug 9, 2015 at 10:05:12 PM | Cut Geometry in 3D
tonywheal2
Just to clarify, I can do geometry cut to a reference plane in 2D but not in 3D.
Thanks
Sun, Aug 9, 2015 at 10:52:45 PM | Cut Geometry in 3D
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
RP’s are visible only in 2d views perpendicular to the plane. What you see in 3d view (after clicking on Show) is a ‘Work Plane Grid’, not RP.
Cutting in 3d view using RP’s is not possible.
Edited on: Sun, Aug 9, 2015 at 10:53:26 PM
Cut / Join - Geometry (api)
Tue, Jul 29, 2008 at 2:07:19 AM
Cut Geometry tool
Mon, Jan 13, 2014 at 7:30:04 AM
14
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:08 AM
Nested void geometry doesn't cut host solid
Mon, Dec 6, 2010 at 3:18:43 PM
Cut Geometry shows in 3D and Plan but not in Section?
Fri, Nov 30, 2012 at 1:44:30 PM
Page generation time: 1.8529
