Forums >> Revit Building >> Technical Support >> filled regions...
Tue, Mar 28, 2006 at 1:08:08 PM | filled regions...
gdoorn
1 Stars: 1 Votes
a while back i represented some brace frame locations with a simple filled region. i have since located the frames' elements, and no longer need the 'hatching'. however, i cannot locate/tab through to the outline. if i drag a box over the entire filled region, it will not select it. the only thing i can think of is that i changed the cut plane, would this affect my filled regions. all of them are without a perimeter line and i can select none of them. any assistance/advice would be appreciated. Thank you!
Wed, Mar 29, 2006 at 3:33:03 AM | RE: filled regions...
puzzle
4 Stars: 10 Votes
Have you tried turning different elements off? Sorry can't be of more help.
Macca
Sunshine Coast
QLD Australia
Wed, Mar 29, 2006 at 8:09:20 AM | RE: filled regions...
reviteer
1 Stars: 1 Votes
I once had something happen to me in very similar fashion, on an earlier release of Revit, 7.0 i think it was, it may have been 6.1. Anyhow, the same thing happened to me, and no matter what I did, I could not get to that filled region, yet it would show in every print. I finally ended up creating a duplicate view, and then copy-paste all the annotations and other detail elements into the new view. I then erased the old view entirely. It was almost as if the old view was "damaged" in some form, and could not be repaired. Anyways, the method I stated above took about 4 seconds, and it solved the issue. Submitted that problem to Autodesk, and never heard back from them...
Sat, Jun 13, 2009 at 4:48:38 PM | filled regions...
Sparhawk
I found the problem.  Thin lines, used to create the region, had been turned off.
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions on an elevation
Wed, May 25, 2005 at 1:35:38 PM
Revit 2014 Filled Regions
Fri, Jun 27, 2014 at 4:47:56 PM
11
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Page generation time: 0.1682
