Forums >> General Discussion >> Revit Project Management >> Can the appearance of materials change by view type?
Wed, Aug 5, 2015 at 3:32:04 PM | Can the appearance of materials change by view type?
jrlucas
I would like window glass to be shaded solid gray in elevation views, but retain it's transparent appearance in 3D and section views. Since the "Patterns" and "Transparency" categories for window glass are not editable in Visibility Graphics, is there another way to accomplish this? Thank-you.
Wed, Aug 5, 2015 at 4:04:02 PM | Can the appearance of materials change by view type?
Realistic views allow material settings to control so if your glass has a transparency, that will work.
If windows are built correctly, you can turn off the glass sub-category in view's VG and thus...see through windows.
Edited on: Wed, Aug 5, 2015 at 4:04:29 PM
Can I change materials and render appearance on components from revit city?
Tue, Nov 30, 2010 at 9:35:35 PM
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ]
Fri, Aug 8, 2008 at 6:11:21 PM
31
Appearance Property Set default
Mon, Mar 5, 2012 at 3:00:19 PM
Revit 2013: Family Materials Graphics vs Appearance
Wed, Mar 20, 2013 at 7:38:52 AM
How do you change the material and color of a download?
Tue, Aug 6, 2013 at 7:31:46 AM
Page generation time: 0.9663
