Forums >> Revit Building >> Technical Support >> Nested family parameters
Mon, Aug 3, 2015 at 11:48:21 AM | Nested family parameters
Profiil
I am having trouble understanding how one of the families is created in the download area.
http://www.revitcity.com/downloads.php?action=view&object_id=10032
The questions are:
1. Where is the spacing set? usually I put it one of the views as dim lines where I add an lable. I cannot find it from this one.
2. What are the conditions for matching nested family parameters.E.g there is nested sunshade which has Height. And there is total high on the host family. If I lock host family ref lines and give it an lable and change the value then it underconstrains it. How Can i transfer over the new value into nested family (Height value).
Hopefully i explained well enough, thank you
Mon, Aug 3, 2015 at 12:12:54 PM | Nested family parameters
The spacing is fixed - not variable.  The number of blades is set by a formula in the nested louver family.
Nested family: no option to choose the little button
Mon, Jul 27, 2015 at 9:11:37 PM
Nested family always vertical?
Mon, May 16, 2011 at 2:55:02 PM
Nested Families and System Parameters
Fri, May 8, 2015 at 9:47:41 AM
Creating nested Family Parameters
Fri, Jun 26, 2015 at 3:52:28 AM
Scheduling shared parameters of nested famiies?
Sun, Apr 26, 2009 at 1:56:12 PM
Page generation time: 0.6398
