10 Users Online (8 Members):
Forums >> General Discussion >> Revit Project Management >> Is there a way to force walls to show section?
in a plan view: is there a way to force walls to show section without changing the view range?
I have foundation walls that are only 16" tall which i can make show section (internal structure) however the foundation wall slopes
down 2' across the building. which means there is no elevation that i can cut all of the walls. so can i force the walls to graphically show
the section without modifying the wall heights which will screw up the model.
How about using a plan region?
@WWHub perfect thank you. i din't know how to use plan region, it seems like it was developed exactly for the issue i was having. Thank you for your help.
be careful not to go wild with plan regions. They can be overused and add a lot of confusions to your sheets. And NEVER hide them--they do not print, so just ignore the dashed green lines.
Walls don't show in section view |
Fri, Oct 26, 2012 at 12:30:09 PM
walls in section |
Sun, May 30, 2004 at 6:27:17 PM
Wall Section won't show in both plan and building section |
Wed, Jan 29, 2014 at 6:52:25 AM
Force Flow Entrance heater |
Thu, Mar 19, 2009 at 3:55:31 PM
Walls wont show in section. |
Tue, Nov 8, 2016 at 10:10:55 AM
12
