Forums >> Revit Building >> Technical Support >> I can't see the pattern on a subregion of toposurface. hence can't rotate it.
Sun, Aug 2, 2015 at 2:29:00 AM | I can't see the pattern on a subregion of toposurface. hence can't rotate it.
danezeq
I'm am trying to see the pattern of a material so i can rotate it (to rotate the apperiance pattern) but it's missing. i trying to change the display, change the pattern and change the pattern from drafting to model and vice versa, lots of times.
what should i do to see the pattern and then rotting it?(my final purpose is to rotate the apperiance pattern)
https://www.youtube.com/watch?v=l6d1x6n6Xnw
Sun, Aug 2, 2015 at 12:00:46 PM | I can't see the pattern on a subregion of toposurface. hence can't rotate it.
Revit will not show surface patterns on topography period - you can find that answer in your help.
You could play around with rotating the moel image in the material editor but that would be a real pain.
Maybe this area could be a slab?
Photoshop?
Sun, Aug 2, 2015 at 2:37:12 PM | I can't see the pattern on a subregion of toposurface. hence can't rotate it.
danezeq
"Slab" means floor? or structure>foundation>slab? (i never tried it)
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
Unweildy subregion
Tue, Mar 28, 2006 at 4:19:07 PM
Adding a subregion to a second toposurface
Thu, Apr 18, 2013 at 3:01:18 PM
Subregion changes topo's elevation?
Mon, Nov 24, 2014 at 4:12:40 PM
Subregion Line Weight
Tue, Oct 2, 2007 at 7:50:14 AM
Page generation time: 2.7832
