19 Users Online (17 Members):
Forums >> General Discussion >> Wishlist >> Combine multiple sheets into a single PDF file per THE SHEET INDEX
Does any way to print out an entire project into a single PDF file following the sheet order per the SHEET INDEX?
Usually a project sheets are following the disciplines, which listed in the Sheet Index; however the batch printing are following the alphabetic order. It's pretty annoying to manually rearrange them everytime.
Only if you use something like: http://www.xrev.com.au/
We have cute make a combined file then use Adobe to clean up the organization.
WWHub,
Appreciated! Maybe its the time to learn how to write small apps for Revit. J
revit multipage printing |
Mon, Aug 2, 2010 at 8:58:09 AM
PDF File Names |
Thu, Apr 7, 2011 at 8:37:37 AM
Sheet / Drawing Index / List Check Box |
Thu, Dec 18, 2008 at 8:48:15 AM
Links to each sheet in sheet index |
Sun, Aug 21, 2016 at 11:06:31 AM
imaginary sheets in the index |
Mon, Sep 8, 2008 at 7:08:30 PM
