Forums >> Revit Building >> Technical Support >> MODEL TEXT IN FAMILIES IS THERE A BUG IN HERE?
Tue, Mar 28, 2006 at 2:35:51 AM | MODEL TEXT IN FAMILIES IS THERE A BUG IN HERE?
robert
when using model text in a project the text is placed on the face of the reference plane which faces the viewer (or in plan view it is between the reference plane and the viewer) and here it is clearly visible displayed as a "ghost" at the end of the curser prior to inserting, which to me is the logical way. not so when in a family: if the front elevation is selected to work in and the work plane selected is centre front back and when picking the modeltext button the text does not appear at the end of the curser one is not prompted to select a work plane and one has to go to tools to set the worplane. after inserting the text, it is visible in all views except the one you are working in fantastic. one way to see the text is to push it bacwards away fron the reference plane or insert it in the back elevation as i was told by the vendor what am i doing wrong or what is wrong with the model text? why can't revit stick to the same method as in projects robert melbourne
Text problem on 3D views
Tue, Nov 9, 2010 at 8:20:38 AM
Text in Families
Mon, Nov 17, 2008 at 10:27:15 AM
Text in Families
Fri, Jul 21, 2006 at 11:34:55 AM
REVIT 2011 BUG OR NOT BUG?
Mon, Dec 6, 2010 at 6:28:30 PM
Text in Families to align to bottom of sheet
Sun, Nov 21, 2010 at 9:10:23 AM
Page generation time: 0.8744
