Forums >> Revit Building >> Technical Support >> Deleting Levels without deleting associated walls
Thu, Jul 30, 2015 at 12:25:41 PM | Deleting Levels without deleting associated walls
aricbouwers
I've got a pretty unique situation here. We are designing townhomes right now, and we have two that are essentially mirrored versions of each other. We finished one to 100% drafting perfection and decided to attempt to save DAYS (if not weeks) of drawing time by mirroring the entire project (model, annotations, dimensions, everything) and shift the model around a bit after to fit the grading of the site. We successfully mirrored the entire project by using the grid line that you see in the centre of the screen capture.
What i've ran into is trying to delete the annotations of the model that we copied from. What's going on is that the walls and floors and stuff that are on our new project (right part of screen capture) that we copied from the old project (the annotations on left of screen capture) , are still associated to the levels that i want to delete (the levels on the left of screen capture, attached). When i try to delete the levels from the old project, it takes with it all of the associated wall/floors/roofs (basically everything) and deltes those. Is there a way to delete these levels without having this happen?
Thu, Jul 30, 2015 at 12:27:15 PM | Deleting Levels without deleting associated walls
aricbouwers
***Version of Revit that I am using for this project is Revit 2015***
Thu, Jul 30, 2015 at 12:35:17 PM | Deleting Levels without deleting associated walls
Is it too late to use the better process?
Since about 2010, the "mirror project" tool has been available in Revit.  It mirrors the whole project, not just model elements and it works.
Thu, Jul 30, 2015 at 1:31:13 PM | Deleting Levels without deleting associated walls
aricbouwers
Better process being what? this way we can keep all the annotations, all the modelling without needing to start from scratch, etc. The levels that are still in the model are definitely annoying, but if they can't be dealt with, it's still worth it based on the amount of time we are saving on the project
Thu, Jul 30, 2015 at 1:32:05 PM | Deleting Levels without deleting associated walls
aricbouwers
I guess i didn't quite read all of your response. Where is this "mirror project command"?
Thu, Jul 30, 2015 at 1:38:36 PM | Deleting Levels without deleting associated walls
Manage tab / position pulldown.  That should fix all your problems.
Thu, Jul 30, 2015 at 2:25:14 PM | Deleting Levels without deleting associated walls
aricbouwers
WOW. You just saved my bacon! Worked flawlessly, and there's no junk to deal with now. Thanks very much!
Thu, Jul 30, 2015 at 2:43:47 PM | Deleting Levels without deleting associated walls
aricbouwers
here's another question. Now that i've got it mirrored, I need to adjust the entire one half of the project DOWN, as the site drops more on this unit than the one i mirrored off of. Is there a way to do this so that it changes the elevations of the levels, but keep walls and floor and annotations intact?
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
deleting levels without deleting associated objects on it.
Thu, Aug 1, 2013 at 6:20:35 AM
How do you Delete levels without deleting everything associated to them???
Tue, Jan 24, 2012 at 8:17:42 AM
Rev 13 deleting un-used levels
Tue, May 22, 2012 at 11:13:53 AM
Mystery of the deleted level tag.
Wed, Aug 20, 2008 at 11:52:51 AM
Page generation time: 0.8003
