Forums >> Revit Building >> Technical Support >> Demolishing wall layers
Wed, Jul 29, 2015 at 12:10:07 PM | Demolishing wall layers
aaronkennedy
So I am working on a renovation project where we have multiple phases.  In my phase 2 demolition I created parts on an exterior brick on wood stud wall and deleted the brick.  However it is still showing up in phase 2 drawings. I have checked the phases to make sure all is in order and as far as I can tell it is.  Any help would be appreciated.
Thanks,
AAron
Wed, Jul 29, 2015 at 12:30:14 PM | Demolishing wall layers
I believe you need to set the parts in the existing phase, uncheck the phase demolished by original then in new phase you can demo that part.
Wed, Jul 29, 2015 at 12:38:58 PM | Demolishing wall layers
We still don't use parts because we see problems.   Parts seem to be view specific.
Wed, Jul 29, 2015 at 1:58:15 PM | Demolishing wall layers
aaronkennedy
Thanks WWhub, view specific make sense as to what I am seeing.  Any way to do this besides making two walls. Studs and sheathing, and a brick wall and demolishing the brick "portion"?  My problem is it is showing up as full thickness and I want those couple of extra inches.  Thanks
Wed, Jul 29, 2015 at 3:49:52 PM | Demolishing wall layers
No easy solution.   We have always used two walls.
Wed, Jul 29, 2015 at 4:08:57 PM | Demolishing wall layers
aaronkennedy
I made a "hidden" (not shown on any sheet) phase and just demolished it and built a new 2x wall in the same hidden phase.  Next time I think I will make it two walls.
wall layers not wrapping at curtain wall inserts!
Fri, Mar 4, 2016 at 10:27:08 PM
Scheduling Wall Layers
Wed, Nov 4, 2015 at 11:24:08 AM
Wall Layers in Section Views
Wed, May 5, 2010 at 3:46:43 PM
Wall Layers Modify
Fri, Dec 31, 2004 at 8:41:03 AM
Seperating layers hatch with filter
Wed, Feb 12, 2014 at 3:15:30 AM
Page generation time: 1.4062
