Forums >> Revit Building >> Technical Support >> Columns with voids
Wed, Jul 29, 2015 at 11:18:57 AM | Columns with voids
trmurphy21
hi. i have a column family that i have attached a void to (full length and 25mm offset) with the intention of it cutting the slab but instead it cuts the beams connected to it. i've tried the uncut tool for the beams and the cut tool for the slab but neither work. i have the cut voids box ticked. using revit 15.
i've attached an example of whats happening with the void exaggerated to 500mm
cheers!
Wed, Jul 29, 2015 at 2:06:47 PM | Columns with voids
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
If you need rectangular openings through a floor or multiple floors, use a shaft tool.
Thu, Jul 30, 2015 at 2:09:31 AM | Columns with voids
trmurphy21
cheers the plan is i need a slab layout but the columns are still moving around and i'd like the void to move around with them. is there any reason why the attached void wouldn't work?
Thu, Jul 30, 2015 at 9:07:46 AM | trmurphy21
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting trmurphy21 from 2015-07-30 02:09:31
Shaft opening sketch can be locked to your column, so it moves with it.
After doing some testing with a void, I can’t recreate your problem, all is working fine here. The void cuts only items that I pick with the cut tool. Can you upload your column family, so we can troubleshoot?
Partially Demolish Columns
Fri, Sep 30, 2022 at 12:33:28 AM
Structural Columns not cutting walls
Mon, Jan 4, 2016 at 4:13:25 PM
Wall by face on curved solid - VOIDS not seen
Mon, Jul 29, 2013 at 1:29:54 PM
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
A Problem with Voids
Fri, May 18, 2012 at 8:41:19 AM
Page generation time: 4.7226
