22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> ? in tags with blank values
Hi,
I'm creating a door tag to display any signage the door has (signage instance parameter in the door).
I want to tag all doors, so that if someone adds any signage the it is automatically shown in an existing tag.
But the issue is that some doors dont have any signage and so the tag displays '?'.
Is there any way to supress the question mark, ideally I don't want the tag to display at all if there is no value in the signage parameter.
Thanks.
The version of Revit I have (Revit 2015) does not show a question mark in a blank tag. It is just blank. My preliminary research shows that if you are working in an older verion of Revit it does as you say and there is nothing you can do until you populate the tag.
See this.
http://forums.augi.com/showthread.php?132636-Blank-Labels-Display-as-Question-Marks
I'm using 2015 Update release 9 - which I understand is the current version? Is that the same as yours?
room tag blank field |
Tue, Sep 25, 2007 at 8:33:16 PM
Blank values in parameters |
Thu, Oct 3, 2013 at 7:16:05 AM
Blank mark door tags for unit plans |
Tue, Aug 16, 2011 at 11:40:36 AM
length in beam tag |
Wed, May 23, 2012 at 7:27:00 AM
Calculated Values in Room Tags |
Wed, Mar 30, 2011 at 4:08:03 PM
