Forums >> Revit Systems >> Tips & Tricks >> Hope this Helps Anyone w/ This Issue
Mon, Jul 27, 2015 at 1:53:12 PM | Hope this Helps Anyone w/ This Issue
Pikachu123
On occasion, when you are in the situation of connecting to something you have already drawn. The element you are connecting to disappears, and not when the size you are making it is unavailable, and the family becomes that strange-looking detail line thing (like if you were in course display or something). It just vanishes, right before your eyes... like some kind of awful magic trick, =).  This happens with SysQue, and Revit running alone.
        --Situation Example--
You have a Tee in a vertical drop, and you have both the End's connected, but not the branch yet. You go to draw a pipe to the tee, and *POOF*... gone.
Possible Solution: I found a lot of the time if you "Pin" the element that keeps disappearing on you, and try to reconnect 9/10 times it fixes this issue. This doesn't always work, but it is my first "go-to" solution that i try when this does happen to me.
Shared Parameters in Wire Type family
Wed, Mar 28, 2018 at 12:56:44 PM
Align painted surface
Fri, Jul 22, 2016 at 1:28:22 PM
Phase Filter - Can't change from "Show All", Greyed out
Mon, Sep 24, 2012 at 1:17:42 PM
TitleBlock Labels
Mon, Jan 23, 2006 at 1:55:38 PM
Feet per second squared error? What??
Tue, Feb 12, 2013 at 11:59:20 AM
Page generation time: 1.3028
