Forums >> General Discussion >> Wishlist >> sheet view order
Fri, Jul 24, 2015 at 9:45:22 AM | sheet view order
cynnamon79
Does this (or could this) exist....
Say I have the following views....they currently appear alphabetically in the plan view list:
T/ Masonry: 12'-0"
T/Slab: 0'-0"
Roof: 14'-0"
When I create them, I'd like them to show in the order of their elevation height instead:
Roof: 14'-0"
T/ Masonry: 12'-0"
T/ Slab: 0'-0"
I've noticed if I change the name plotted/shown on the detail marker, that can affect the list order, but I don't always trust the fellow workset users to not mess something up there. Is there currently a setting that puts them in order of elevation height? Because that would be awesome, especially when I have large lists and alphabetically does nothing for me! Smile
Fri, Jul 24, 2015 at 10:00:29 AM | sheet view order
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can add a Project parameter to the sheet and then in your Browser Organization Properties set it to filter by that parameter.  For example create a Project Parameter called Sheet Order, then in the properties you would have to put a number in the Sheet Order parameter such as
1 = Roof: 14'-0"
2 = T/ Masonry: 12'-0"
3 = T/ Slab: 0'-0"
Then you can set your Browser organization to Sort by Sheet Order.
Fri, Jul 24, 2015 at 10:28:05 AM | sheet view order
cynnamon79
As I was going thru the steps you suggested, I came across an even better solution:
- View tab, Windows panel, User Interface dropdown: Browser Organization
- Select/check: "All Disciplines", then edit
- Grouping tab, at the bottom change Sort by to: "Associated Level" and choose decending; okay, apply...
BINGO!
Thanks so much! :D
View List doesn't have parameter to show them in order of number on sheet?
Fri, Aug 26, 2016 at 2:48:10 PM
controlling drawing order of views on a sheet
Mon, Mar 7, 2011 at 12:30:49 PM
Element ReNumber and Sheet Order Apps
Wed, Sep 23, 2009 at 5:54:20 PM
SHEET INDEX ORDER
Sat, Dec 12, 2009 at 9:14:52 AM
View Overlay Order on Sheets
Wed, Mar 25, 2015 at 2:53:03 PM
Page generation time: 6.5686
