Forums >> Community >> Newbies >> foundation wall tag
Wed, Jul 22, 2015 at 11:53:46 AM | foundation wall tag
husam3
For some reson I can't tag the foundation wall at the foundation plan,what I'm missing ?
I'm trying to use spot elevation to set the top of foundation wall,I can tag just the footing,help please
Wed, Jul 22, 2015 at 12:28:47 PM | foundation wall tag
What Revit version?
What Tag?  You say tag but then you say spot elevation.  So if elevation, what spot elevation family?
You also say top of foundation wall.  So is your view cut above the top of the wall?  (AND there is no wall on top of this wall - correct?
Edited on: Wed, Jul 22, 2015 at 12:30:10 PM
Wed, Jul 22, 2015 at 12:36:49 PM | foundation wall tag
husam3
thank you for respond !! revit 2014,yes elevation spot to show the top of wall foundation and foorting at the foundation plan
the spot elevation family ( top of wall )
yes my view is above and I tried the plan region to show the foundation wall cut but didnt work for me for some reson
Edited on: Wed, Jul 22, 2015 at 12:37:53 PM
Wed, Jul 22, 2015 at 1:08:32 PM | foundation wall tag
It works fine for me so it is your process.
  • This is truely a plan view - not a 3D set to plan
  • The elements are in the view, not in an underlay.
  • You can see the elements - they are not hidden by something like a floor or a transparent item.
  • The spot elevation is ON in the view VG.
  • Why did you write: "the spot elevation family ( top of wall )' ?   Spot elevations are for everything.   You are not using something else - correct?
Wed, Jul 22, 2015 at 1:22:24 PM | foundation wall tag
husam3
thank you,It's work just fine
Wall Foundation Tag - Width and Thickness
Fri, Jun 10, 2011 at 6:25:13 AM
Split Region Wall Foundation Issues
Wed, Jun 1, 2011 at 5:36:25 PM
WALL FOUNDATION CORNER
Tue, May 5, 2015 at 10:17:12 AM
Cant tag a wall, with the tag aligned with the wall
Wed, Oct 10, 2007 at 4:24:04 PM
Foundation Wall Family Edit
Mon, Apr 20, 2009 at 5:53:01 PM
Page generation time: 0.6031
