Forums >> Revit Systems >> Tips & Tricks >> Hold Clouds
Tue, Jul 21, 2015 at 8:55:18 AM | Hold Clouds
WmMerrill
Working currently in Revit 2015. I am wondering if there is a way to use the revision clouds as HOLD clouds.  I do not want this cloud to appear in the revision block.  Is there a way?  I thought I had done this previously.  Any thoughts or advice will be welcome.
Thanks
Tue, Jul 21, 2015 at 10:00:52 AM | Hold Clouds
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I’m not sure what the Hold Cloud is, but try this. Start with the rev cloud, draw whatever shape you need, copy to clipboard before you exit sketch mode (magenta lines), hit X to terminate rev cloud command and use paste. They are just lines now, not rev cloud object. You can even stretch, move to any size you need.
Revit clouds
Tue, Jul 29, 2014 at 10:43:12 AM
Revision Clouds
Tue, Dec 18, 2007 at 10:52:44 AM
Why no clouds
Thu, Dec 5, 2019 at 5:35:53 PM
Rev Clouds
Thu, Mar 27, 2008 at 6:07:04 PM
Revision clouds - off on one sheet but not on other sheets - is this possible?
Fri, Mar 16, 2012 at 9:13:39 PM
Page generation time: 0.4995
