Forums >> Revit Building >> Technical Support >> Wall tag that includes detail reference
Fri, Jul 17, 2015 at 12:09:32 PM | Wall tag that includes detail reference
DavidLarson
I'm trying to create a wall tag that resembles a detail bubble but has the top calling out the wall type and the bottom the sheet where the detail for the wall is located.  Is this even possible and if so, how?  Please use small words, it's Friday and it's been a hell of a week.  My brain hurts.  I'm using Revit 2015
Do you even Revit bro?
Fri, Jul 17, 2015 at 12:24:50 PM | Wall tag that includes detail reference
Callouts are not available in tags.  Only shared parameters can be used in tags.   So knowing this:
  1. Created a new shared parameter - let's call it 'SHOWN ON'.
  2. In your project (or template), load this shared parameter as a project parameter and assign it to walls.  (Probably type based)
  3. Edit your wall tag and add this shared parameter to the tag family and load it into project (template).
You will have to assign the sheet number to this parameter for those wall types.
Fri, Jul 17, 2015 at 12:50:19 PM | Wall tag that includes detail reference
DavidLarson
Thanks.  Right after doing that I saw many more ways to use such parameters.  Yay!
Detail reference tags
Tue, Feb 7, 2017 at 11:22:08 AM
Detail callout tag... for 2010
Wed, Nov 11, 2009 at 11:58:51 AM
Detail tag to reference consultant files
Mon, Dec 17, 2007 at 4:22:09 PM
detail callout tag, multiple times on the same view
Thu, Oct 8, 2009 at 1:16:25 PM
detail callout reference similar is greyed out
Fri, May 22, 2020 at 12:10:28 AM
Page generation time: 0.8524
