23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Room Tag Leader Arrowhead Problem
Hello, first post here,
My firm is using filled dot 1.5mm arrow heads for our room tag leader arrowhead, they appear perfectly in plan view, they appear fine in most rooms in section, however one room the dot looks squished almost like an elipse. Any idea on how to fix this issue?
I have tried moving the room origin, the leader arrowhead type, the orientation and can't get it too look correct.
NVMD, fixed it.
There is a grip in the middle of the leader, apparently if you click it and move it around a bit, the leader arrowhead resets. I guess. Weird bug.
I know its been years since you posted this but I would have never figured that out without your post! Thanks.
Custom leader arrowhead |
Tue, Jan 27, 2009 at 1:34:05 PM
Default Tag Leader Arrowhead |
Mon, Dec 15, 2008 at 4:39:50 PM
Room Tag w/o leader |
Fri, May 6, 2016 at 7:01:51 AM
Controlling the leader line in a floor tag |
Wed, Jan 28, 2015 at 5:13:29 PM
Leader line position from Room tag |
Thu, Aug 9, 2007 at 6:44:38 PM
